Nelysis
The Vanguard system is a Real-time AI engine that monitors and prevents operational & cyber threats on physical security and BMS networks. Vanguard MSM and the Vanguard NCM Core servers, provides complete visibility, profiling and classification of every component in the monitored network. Vanguard...
can work seamlessly with the existing command-and-control and video management system, or as a stand-alone.
Out-of-band design and passive installation - requires zero downtime with no impact on system performances.
Agentless - requires no installation on any monitored component.
Specifically designed for physical security and BMS systems while assuring security and performance needs.
The Vanguard system provides complete and constant visibility, profiling and classification of every component in the network.
Simple, intuitive platform that can be used by non-technical personnel.
What we do
Located at:
Israel
Holon
Israel
