Promise Vess NVRs Certified with Milestone XProtect, Preloaded Solution Available Exclusively from ADI Global Distribution
The Milestone certification process ensured that integrators & end users of the surveillance systems which incorporate Vess A-Series NVRs & XProtect VMS can have confidence that the system will record & archive video reliably
Promise Technology announced that its Vess A2330 and Vess A3340 network video recorders (NVRs) have been certified by Milestone Systems for use with the whole range of XProtect video management software (VMS) products. Both the Vess A2330 and A3340 easily supported the benchmark video data throughput levels as recommended by the Milestone Server and Storage Calculator. In maximum performance testing, it was further determined that the Vess A2330 and A3340 NVRs can support twice the number of cameras as recommended by the calculator.
Promise was one of the first hardware vendors to be certified in 2014 by Milestone, the number one global VMS provider according to IHS, and by qualifying the new Vess A2330 and A3340 NVRs with XProtect VMS it provides customers with more possibilities to solve their security challenges. The Milestone certification process tested the solution’s functionality, performance impact and usability. The test results ensure that integrators and end users designing, installing and operating surveillance systems which incorporate Vess A-Series NVRs and XProtect VMS can have confidence that the system will record and archive video reliably.
“Promise Technology has certified their complete range of Vess A-Series NVRs through the Milestone Systems certification program. The system performs at a high level of data throughput, and with good read/write latency when using the optimal logical disk configuration. Customers who wish to gain the maximum value and performance out of their surveillance system can also refer to the best practices and performance limitations outlined in the certification documents provided by Promise Technology and Milestone Systems to help design a system,” said Trine Voss, Head of the Solution Partner Program at Milestone Systems. “The joint efforts between Promise Technology and Milestone Systems to deliver surveillance solutions to the market that are validated and optimised for integrators and end users is a result of a strong strategic collaboration between our companies.”
Read the full article on Milestone's new certified NVR partner Promise Vess here.
