Khan Bank: Helping Mongolia Grow Since 1991
Khan Bank is one of the largest commercial banks of Mongolia. It provides banking services to an estimated 80% of Mongolian households.
The Challenge: Khan Bank’s Previous Security System Unable to Keep Pace. A Trial is Held to Determine the Ideal Solution.
In this climate of rapid growth and expansion, Khan Bank required a thoroughbred surveillance system which could keep pace with its changing demands and keep Khan Bank ahead of the field. At the heart of any bank is its ability to secure its customers’ property, and as such the safes at each of Khan Bank’s branches required the utmost level of security. Unfortunately, the bank’s previous security system was not able to keep up with Khan Bank’s security needs, leading to a need to revolutionize its entire security system.
High-Quality IP Cameras Secure a Vast Network of Banking Facilities.
The largest demand for coverage was found in the halls of Khan Bank branches. These wide spaces required cameras with extremely wide-angle coverage and high image quality, while also blending in with the interior design of the bank’s branches. For this task, ITZONE LLC chose VIVOTEK’s FE8174 for its combination of high coverage, high quality and low profile. The FE8174 is capable of 180 degree panoramic views while mounted on the wall, or 360 degree surround views if mounted on the ceiling.
IP Video suriveillance
To add to the functionality of their system, Khan Bank uses Milestone XProtect® Enterprise, which is an easy-to-use video management software platform designed especially for large-scale and multi-site surveillance applications. It supports intuitive control of an unlimited number of cameras for monitoring live video, recording, and sharing evidence. All the video captured across multiple branches can be transmitted back to the main XProtect management and displays in the central control room. The security staff can instantaneously view events at different sites via the unified, intuitive interface, increasing bank operational efficiency and speeding the reaction time whenever events occur.
Read the full customer case story about Milestone and Khan Bank.
