The Settings window lets you control which features and elements, for example, language selection, joystick setup and keyboard shortcut setup, you want to use on each of the tabs. For languages where your normally read and write from right to left, you can choose to enforce a visual left-to-right interface if needed.
Open the Settings window from the application toolbar:
In this section |
© 2018 Milestone Systems A/S
