The Timeline settings let you specify your general timeline settings.
If available, the Follow Server column lets you specify that you want your XProtect Smart Client to follow the recommended settings of the server. Certain settings are server-controlled, in which case, configuration on the server decides whether you can override the settings.
Name |
Description |
Incoming audio |
Select to show or hide incoming audio on the timeline |
Outgoing audio |
Select to show or hide outgoing audio on the timeline. |
Additional data |
Select to show or hide additional data from other sources. |
Additional markers |
Select to show or hide additional markers from other sources. |
Bookmarks |
Select whether to show or hide bookmarks on the timeline. |
Motion indication |
Select whether to show or hide motion indication on the timeline. |
All cameras timeline |
Select whether to show or hide the timeline for all cameras. |
Playback |
Select whether or not to skip gaps during playback. |
© 2018 Milestone Systems A/S
