The Functions settings let you specify the functions (for example, playback on the Live tab) that you want to display on a particular XProtect Smart Client tab.
The Mode column displays where the pane is available, the Function column displays the name of the function, and the Setting column lets you specify whether or not you want the pane to be available.
If available, the Follow Server column lets you specify that you want your XProtect Smart Client to follow the recommended settings of the server. Certain settings are server-controlled, in which case configuration on the server decides whether or not you can override the settings.
Functions:
Name |
Description |
Live > Camera playback |
The ability to play back recorded video from individual cameras on the Live tab. |
Live > Overlay buttons |
The ability to view and use overlay buttons on the Live tab for activating speakers, events, output, moving PTZ cameras, clearing indicators from cameras, etc. |
Live and Playback > Bookmark overlay button and View position toolbar |
Select whether you want to add quick or detailed bookmarks from the view position toolbar or through ready-made overlay buttons on the Live and/or the Playback tab. Note that enabling/disabling this option on the Playback tab will control whether or not the corresponding button is enabled on the Sequence Explorer tab. The bookmark feature is only available if connected to certain surveillance systems. Depending on your user rights, access to adding bookmarks from some cameras may be restricted. Note that you may be able to view bookmarks even though you may not be able to add them, and vice versa. |
Live and Playback > Print |
The ability to print from the Live and Playback tab. Note that enabling/disabling this option on the Playback tab will control whether or not the corresponding button is enabled on the Sequence Explorer tab. |
Live and Playback > Bounding boxes |
The ability to show bounding boxes on live video on the Live tab or on recorded video on the Playback tab on all cameras. Bounding boxes are used for, for example, tracking objects. The bounding box feature is only available if connected to certain surveillance systems and to cameras that support metadata. Depending on your user rights, access to bounding boxes from some cameras may be restricted. |
Playback > Independent playback |
The ability to play back recorded video from individual cameras independently on the Playback tab, where all cameras in a view otherwise by default display recordings from the same point in time (the playback time). |
Setup > Edit overlay buttons |
The ability to add new or edit existing overlay buttons in setup mode. Note that to add overlay buttons, the Overlay Buttons list must be set to Available (you manage this on the Panes tab in the Settings window). |
Setup > Edit video buffering |
The ability to edit video buffering as part of the camera properties in setup mode. Note that in order to edit video buffering, the Setup tab's Properties pane must also be made available (you manage this on the Settings window's Panes tab). |
© 2018 Milestone Systems A/S
