Enter the Bing Maps key or Google Maps client ID or key for the Bing Maps API or Google Maps API that you use.
Note: You can edit these settings only if your administrator has allowed you to in Management Client.
Name |
Description |
OpenStreetMap geographic background |
Specify whether the OpenStreetMap service can be used as a geographic background. If you select Unavailable, XProtect Smart Client does not display it as an option. |
Alternative OpenStreetMap tile server |
To use a different tile server for your OpenStreetMap than the one specified in the configuration, enter the server address here. |
Create location when layer is added |
Specify whether to create a location when a user adds a custom overlay. For more information, see Add or delete a custom overlay on smart map . |
Bing Maps key |
Enter or edit the private cryptographic key that you generated for the Bing Maps API. |
Client ID for Google Maps |
Enter or edit the client ID that you generated for the Google Static Maps API. |
Private key for Google Maps |
Enter or edit the private cryptographic key that you generated for the Google Static Maps API. |
Remove cached Smart Map files |
Smart map saves to the cache on your local computer so that it can load faster. Use this setting to specify how often you want to remove the cached files. |
© 2018 Milestone Systems A/S
