You can specify a different tile server for OpenStreetMap than the standard server specified in the configuration for your type of user profile. For example, if your VMS is not connected to the Internet, you can use a local server. Or you can use a commercial server.
Requirements: If the tile server specified in the configuration has been locked for editing, the field is grayed out in XProtect Smart Client, and you cannot change the server. Please contact your system administrator to help you enable the feature on the Smart Client profile in Management Client.
Steps:
Settings to open the Settings dialog.
For more information about changing the tile server, see Changing the OpenStreetMap tile server.
© 2018 Milestone Systems A/S
