The Export settings let you specify general export settings.
If available, the Follow Server column lets you specify that you want XProtect Smart Client to follow the recommended settings of the server. Certain settings may already be server-controlled, in which case, configuration on the server decides whether you can override the settings.
Name |
Description |
Export to |
Select the path you want to export to. |
Privacy mask |
Select if you want to cover areas with privacy masks in the exported video. The privacy masks that you add here only apply to the current export and for the selected video. The export may already include video with privacy masks configured by your system administrator. These privacy masks are configured in the Management Client, on the Privacy masking tab. |
Media player format |
Select whether or not you can export in media player format. |
Media player format - Video texts |
Select whether you want video texts to be optional, required or unavailable when you export in media player format. With video texts, the user can add overlay text on the exported recordings. |
Media player format - Video codec properties |
Select if you want codec configuration to be available or not when you export in media player format. The codec properties depend on the selected codec. Not all codecs support this option. |
XProtect format |
Select whether or not you can export in XProtect format. |
XProtect format - Project comments |
Select whether you want project comments to be optional, required or unavailable when you export in XProtect format. |
XProtect format - Device comments |
Select whether you want device comments to be optional, required or unavailable when you export in XProtect format. |
Still image export |
Select whether or not you can export still images. |
© 2018 Milestone Systems A/S
