Alarms triggered by LPR
You can associate some types of alarms with events from XProtect LPR. Do the following:
- Create the license plate match list you want to match license plates against.
- Add and configure your LPR camera(s).
- In the Management Application's navigation pane, expand Alarms, right-click Alarm Definitions and select to create a new alarm.
- The Alarm Definition Information window appears. Select the relevant properties.
- If prompted when done, confirm to save changes.
- Configure the alarm data settings for LPR.
© 2019 Milestone Systems A/S
