In the Management Application, you must make two specific Alarm List Configuration elements available for selection in XProtect Smart Client.
These two elements are used for configuring alarm lists in the Alarm Manager tab in XProtect Smart Client. The relevant elements are Object, Tag, and Type, which are essential for recognizing license plate numbers (Object) and country codes (Tag).
Do the following in the Management Application:
© 2019 Milestone Systems A/S
