Add new license plate match lists
- In the Management Application's navigation pane, select License plate match lists, right-click and select Add New.
- In the window that appears, give the list a name and click OK.
As soon as you have created a license plate list, it becomes visible in the License plate match list and on the Match lists tab for all your LPR cameras.
- If you want to add columns to the match list, click Custom field and specify the columns in the dialog box that opens.
- To update the match list, use the Add, Edit, Delete buttons.
- Instead of defining the match list directly in the Management Application, you can import a file.
- If prompted, confirm to save changes.
© 2019 Milestone Systems A/S
