Import/export license plate match lists
You can import a file with a list of license plates that you want to use in a license plate match list. You have the following import options:
- Add license plates to the existing list.
- Replace the existing list.
This is useful if, for example, the lists are managed from a central location. Then all local installations can be updated by distributing a file.
Similarly, you can export the complete list of license plates from a match list to an external location.
Supported file formats are .txt or .csv.
To import:
- In the Management Application's navigation pane, click License plate match lists and select the relevant list.
- To import a file, click Import.
- In the dialog box, specify the location of the import file and the import type. Click Next.
- Await the confirmation and click Close.
To export:
- To export a file, click Export.
- In the dialog box, specify the location of the export file and click Next.
- Click Close.
- You can open and edit the exported file in, for example, Microsoft Excel.
© 2019 Milestone Systems A/S
