Add LPR camera
To configure cameras for LPR, you initially run the Add LPR camera wizard. The wizard takes you through the main configuration steps and automatically optimizes the configuration.
To run the wizard:
- In the Management Application's navigation pane, expand Servers, expand LPR servers, and select LPR camera.
- Right-click LPR camera.
- From the menu that appears, select Add LPR camera and follow the instructions in the wizard:
- On the last page, click Close.
The LPR camera appears in the Management Application and based on your selections, the system has optimized the recognition settings for the camera.
- Select the camera you have added and review its settings. You only need to change the configuration if the system does not recognize license plates as well as expected.
- In the Recognition settings tab, click Validate configuration.
© 2019 Milestone Systems A/S
