License plate lists are collections of license plates that you want your LPR solution to treat in a special way. License plate recognitions are compared with these lists and if there is a match, the system triggers an LPR event. The events are stored on the event server and can be searched for and viewed on the LPR tab in XProtect Smart Client.
By default, events are stored for 24 hours. To change this, open the Options dialog box in the Management Application and on the Event Server Settings tab, in the Keep events for field, enter a new time frame.
After specifying a license plate match list, you can set up additional events and alarms to be triggered on a match.
Examples:
Triggered events can also be used for making cameras record in high quality or similar. You can even use an event to trigger combinations of such actions.
© 2019 Milestone Systems A/S
