Disable transaction sources
You can disable a transaction source, for example if an ATM is temporarily out of order, or a service on a registered cash register is disabled. The flow of transaction data to the event server is disrupted.
Steps:
- In the Management Application's navigation pane, expand Transact.
- Select Transaction sources.
- Right-click the transaction source and select Properties.
- Clear the Enable check box and save the changes. The transaction source is disabled.
See also
Add transaction source (wizard)
Delete transaction source
© 2019 Milestone Systems A/S
