You can delete the transaction sources you have added. The stored transaction data from that source is deleted from the event server.
As an alternative, you can disable the transaction source to avoid that stored transaction data is deleted. A disabled transaction source also requires a transaction source license.
Steps:
See also
Add transaction source (wizard)
© 2019 Milestone Systems A/S
