Add transaction source (wizard)
To connect data from a transaction source to XProtect Transact, you need to add the sources of the transactions, for example an automated teller machine. In the wizard, you select a connector, and you can connect one or more cameras.
If you do not have a transaction source license for the transaction source you are about to add, the system will work during the 30-days grace period. Make sure that you acquire an additional transaction source license and activate it in due time.
Steps:
- In the Management Application's navigation pane, expand Transact.
- Right-click the Transaction sources node and select Add source. The wizard appears.
- Follow the steps in the wizard.
- Depending on the connector you select, different fields appear that you need to fill in. For more information, see Transaction sources (properties). You can change these settings after completing the wizard.
- If the transaction definition you need is not available, click Add new to create a new transaction definition.
See also
Add transaction definitions
Connectors (explained)
© 2019 Milestone Systems A/S
