After adding a transaction source, you can change the name or select a different transaction definition. Depending on the connector selected, there may be additional settings you can modify, for example the host name and port number of a connected TCP server. In addition, you can disable a transaction source. This will interrupt the flow of transaction data from the transaction source to the event server.
Once you have selected a connector, you cannot change it.
Steps:
See also
Add transaction source (wizard)
© 2019 Milestone Systems A/S
