Activate licenses offline
This topic is only relevant if your surveillance system is offline or if you want to make a manual license activation. If your system is online, your licenses are activated automatically. For more information see About automatic license activation.
You must manually activate your licenses if:
- From the File menu, select Activate License Offline.
- Click Export to export a license request file.
- The license request file is automatically given the same name as your SLC. If you have several sites, remember to make the name unique so you easily can identify which file belong to which site.
- Copy the license request file (.lrq) to a computer with internet access and log into our website for software registration.
- Copy the activated software license file (.lic) that has the same name as your license request file to your computer with Management Application.
- In the same dialog box that you opened in step 1, click Browse to use the activated software license file.
- Click Activate.
If the computer that runs the Management Application does not have Internet access, you can activate licenses offline.
© 2019 Milestone Systems A/S
