Milestone recommends that your surveillance system is online so that your licenses are automatically activated.
When your system is online, the system activates your hardware devices or other licenses a few minutes after you have made your changes. The result is that:
In some cases you must activate licenses manually. Such cases are when you have purchased additional licenses, if you have bought or renewed a Milestone Care subscription, or if Milestone has granted you a higher number of device changes without activation.
© 2019 Milestone Systems A/S
