Available functionality depends on the system you are using. See the Product comparison chart for more information.
When you add generic events, specify the following properties:
Event name |
Specify a name. Names must be unique, and must not contain any of these special characters: < > & ' " \ / : * ? | [ ] Some cameras only support event names of a certain length and/or with a certain structure. Refer to the camera's documentation for exact details. |
Event port |
Read-only field displaying the port number on which your system listens for generic events (default is port 1234). You can change the port number as part of the general event handling configuration. |
Event substring |
Specify the individual items for which your system should look out for when analyzing data packages. Specify one or more terms, then click the Add button to add the specified term(s) to the Event message expression field, the content of which is used for the actual analysis. Examples:
When you add several terms as one item (appearing as, for example, " User001 Door053 Sunday" in the Event message expression field), everything between the quotation marks must appear together in the package, in the specified sequence, in order to match your criterion. If the terms must appear in the package, but not necessarily in any exact sequence, add the terms one by one (they appear as "User001" "Door053" "Sunday" in the Event message expression field). TCP and UDP packages used for generic events can contain special characters such as @, #, +, 㪠~ and more within the text string to be analyzed. |
Event message expression |
Displays the string which will be used for the actual package analysis. The field is not directly editable. However, you can position the cursor inside the field in order to determine where a new item should be included when you click the Add button or one of the parenthesis or operator buttons described in the following. Likewise, you can position the cursor inside the field in order to determine where an item should be removed when clicking the Remove button: The item immediately to the left of the cursor will be removed when you click the Remove button.
Event priority |
The same data package may be analyzed for different events. The ability to assign a priority to each event lets you manage which event should be triggered if a received package matches the criteria for several events. The priority must be specified as a number between 0 (lowest priority) and 1000 (highest priority). When the system receives a TCP and/or UDP package, analysis of the packet starts with analysis for the event with the highest priority. This way, when a package matches the criteria for several events, only the event with the highest priority will be triggered. If a package matches the criteria for several events with an identical priority, for example two events with a priority of 999, all events with the priority in question are triggered. |
Event protocol |
Select which protocol the system should listen for in order to detect the event:
Event rule type |
Select how particular your system should be when analyzing received data packages:
Send e-mail if this event occurs |
Only available if email notifications are enabled. Select if the system should automatically send an email when the event occurs. Recipients are defined as part of the email notification configuration. When using email notifications, remember the individual cameras' scheduling. |
Attach image from camera |
Only available if e-mail notification is enabled. Select to include an image, recorded at the time the event is triggered, in the e-mail notification, then select the relevant camera in the list next to the check box. |
Send SMS if this event occurs |
Select if the system should automatically send an SMS when the event occurs. You define the recipients of the SMS notifications as part of the SMS notification configuration. When you use SMS notifications, remember that you may have set individual camera scheduling. The setting is only available if you have enabled SMS notifications. |
Delete |
Delete a selected event. |
Add |
Add a new event. When the Generic Events node is selected, clicking Add will add a new generic event. When a specific generic event is selected, clicking Add will add a timer event to the selected generic event. |
© 2019 Milestone Systems A/S
