Configure general event handling
Before configuring events of any type, configure general event handling, such as which ports your system should use for event data. Normally, you can just use the default values, but it is a good idea to verify that your organization is not already using the ports for other purposes.
- Expand Advanced Configuration, right-click Events and Output, and select Properties.
- Specify required properties. Your system comes with two simple schedule profiles, Always on and Always off, which you cannot edit or delete. If these do not meet your needs, you can create any number of customized schedule profiles for each camera. You can reuse a customized schedule profile for more than one purpose if you want to.
- Save your configuration changes by clicking Save in the yellow notification bar in the upper-right corner of the Management Application.
© 2019 Milestone Systems A/S
