Name |
Description |
Name |
Shows the name of the list. If needed, you can change the name. |
Custom fields |
Click to specify which license plate entry columns that you or the client user can add additional information to. See Custom fields (properties). |
Search |
Search the list for specific license plates, numbers, patterns or similar. If needed, you can use ? as a single wildcard |
Add |
Click to add a license plate.
Examples: ABC123 (correct), ABC 123 (incorrect), abc123 (incorrect)
Examples: ?????A, A?????, ???1??, 22??33, A?B?C? and similar. Some regional areas might have exceptions to these rules. For example, personalized plates with spaces. Plates with two sets of characters which must be recognized separately by an underscore character ( _ ). Or plates from certain regions with letters on a different background color on parts of the license plate. Example: |
Edit |
Click to edit a license plate. You can select multiple rows for editing. |
Delete |
Click to delete the selected license plate(s). |
Import |
Click to import license plates from any comma-separated file, for example a .txt-file or .csv-file. |
Export |
Click to export the entire license plate list to a comma-separated file, for example a .txt-file or .csv-file. |
Rows per page |
Select how many license plates to display in one page (one screen). You can choose between 50 to 1000 rows. |
Events triggered by list match |
Select which event(s) should be triggered by a list match. You can choose between all available types of events defined in your system. |
© 2019 Milestone Systems A/S
