After you have created license plate match lists, you can associate them with all types of events defined in your system.
The type of events available depends on the configuration of your system. In connection with LPR, events are used to trigger output signals for, for example, raising of parking barrier or making cameras record in high quality. You can also use an event to trigger combinations of such actions. See License plate match lists (explained) for more examples.
Set up system events triggered by list matches
To trigger a surveillance system event, when a license plate that is not on a list is recognized, configure the Unlisted license plates list.
© 2019 Milestone Systems A/S
