Often you would trigger an event when a license plate that is included in a list is recognized, but you can also trigger an event with a license plate which is not included in a list.
Example: A private car park uses a list of license plates to grant residents' vehicles access to the car park. If a vehicle with a license plate that is not in the list approaches the car park, the LPR solution triggers an output signal which lights a sign telling the driver to obtain a temporary guest pass from the security office.
To trigger a surveillance system event, when a license plate that is not on a list is recognized, use the Unlisted license plates list. You select it for a camera like any other list and set it up like any other list.
© 2019 Milestone Systems A/S
