On this tab you select which license plate match list(s) you want a specific LPR camera to match license plates against. You can create as many lists as you need.
Name |
Description |
All |
License plates are matched against all available and future lists. |
Selected |
License plates are matched against the selected lists only. Select one or more from the available lists. |
After changing the settings for your LPR camera, validate your configuration to check if the system recognizes license plates as well as expected.
© 2019 Milestone Systems A/S
