The storyboard function helps you paste together video sequences from one camera or from multiple cameras into one cohesive flow. You can use the sequence of events, the storyboard, as proof of evidence in internal investigations or the court of law.
You can skip all sequences that are not relevant and avoid wasting time looking through long sequences of video that you do not need. Also, you avoid wasting storage space on stored sequences that do not contain relevant video.
When you select the video sequences that make up the storyboard, you can work from the Playback tab in time selection mode. Here you can use the Export > Add to export list function to store multiple sequences in a list without opening the Export window. When you have built the entire list, you can then export the collection of sequences, the storyboard, in one go. You can also export items directly from the Export window.
© 2018 Milestone Systems A/S
