Export items directly from the Export window
To export items by adding them directly in the Export window, follow these steps:
  1. On the Playback tab, to the right of the timeline, click Export > Export to open the Export window with an empty Item list.
  2. Click Add item to add the items, for example cameras, that you want to add to the export list.
  3. Click each export item and then specify its start and end time in the preview pane to the right of the list. Repeat for all items in the list.
  4. In the Export name field, enter a name for the export. By default, the system uses the current date and time. You can change the name.
  5. Specify a path or media burner for the destination of the export.
  6. Click the relevant tab to select a format to export to.
  7. Specify the necessary settings for the format you have chosen. Based on these settings, the program estimates and displays the size of the export at the bottom of the window.
    Note: If the video contains items or information that you do not want to be visible in the export, you can add a privacy mask to hide those areas in the video. For more information, see Mask areas in a recording during export.
  8. Click Start Export to export your evidence.
    Note: If you want to make changes or add more items later, click Cancel. When asked if you want to remove the selected export items, click No. This ensures that your list of export items is available in the Export window when you open it again.
© 2018 Milestone Systems A/S
