Export a storyboard
If you want to export a number of items that make up a storyboard, follow these instructions:
- On the Playback tab, in the timeline, click the Time Selection Mode button.
- For each item that you want to export, select the start and end time and then click Export > Add to export list. This adds each item to the list of exports without opening the Export window. Repeat until you have added all items that you need for your storyboard.
- To the right of the timeline, click Export > Export to open the Export window. All selected items are displayed in the Item list, ready for export.
Click Add item to add additional items. Click Delete All to clear the list.
- In the Export name field, enter a name for the export. The program automatically creates a name with the current date and time. You can change the name.
- Specify a path and/or media burner for the destination of the export.
- Click the relevant tab to select a format to export to.
- Specify the necessary settings for the format you have chosen. Based on these settings, the program estimates the size of the export and displays this in the bar at the bottom of the window.
- Click Start Export to export your evidence.
If you want to make changes or add more items later, click Cancel. When asked if you want to remove the selected export items, click No. This ensures that your list of export items is available in the Export window when you open it again.
© 2018 Milestone Systems A/S
