The Automatic configuration wizard is for easy configuration for first time use of the system. Use the wizard to automatically add cameras to your system using this step-by-step procedure.
Automatic configuration wizard: First page
Automatic configuration wizard: Scanning options
Automatic configuration wizard: Select hardware manufacturers to scan for
Automatic configuration wizard: Scanning for hardware devices
Automatic configuration wizard: Continue after scan
© 2019 Milestone Systems A/S
