Automatic configuration wizard: First page
When you open the Management Application for the first time, the Automatic configuration wizard opens to guide you through the process of adding hardware devices to your system.
If you are new to the system, click Yes, configure to scan your network for available cameras and configure your system. To exit and use a more advanced way of adding devices to your system, click Skip to leave the wizard and go to the Management Application to get more options for setting up your system's device configuration.
© 2019 Milestone Systems A/S
