When you configure alarm data settings, specify the following:
Alarm Data Levels tab, Priorities
Name |
Description |
Level |
Add new priorities with level numbers of your choosing or use/edit the default priority levels (numbers 1, 2 or 3). Use these priority levels to configure the Initial alarm priority setting. |
Name |
Type a name for the entity. You can create as many as you like. |
Sound |
Select the sound to be associated with the alarm. Use one if the default sounds or add more in Sound Settings. |
Alarm Data Levels tab, States
Name |
Description |
Level |
Add new states with level numbers of your choosing. The state levels are only visible in the Alarm List in XProtect Smart Client. You cannot edit or reuse the default state levels 1, 4, 9 and 11. |
Name |
Alarm Data Levels tab, Categories
Name |
Description |
Level |
Add new categories with level numbers of your choosing. These category levels are used to configure the Initial alarm category setting. |
Name |
Alarm List Configuration tab
In Available columns, use > to select which columns should be available in the XProtect Smart Client Alarm List. Use < to clear selection. When done, Selected columns should contain the items to be included.
Reasons for Closing tab
Name |
Description |
Enable |
Select to enable that all alarms must be assigned a reason for closing before they can be closed. |
Reason |
Add reasons for closing that the user can choose between when closing alarms. Examples could be "Solved-Trespasser" or "False Alarm". You can create as many as you like. |
© 2019 Milestone Systems A/S
