When you configure Sound Settings, specify the following:
Sounds  |
Select the sound to be associated with the alarm. The list of sounds contains a number of default Windows sounds. These cannot be edited. However, you can add new sounds of the file type .wav, but only if these are encoded in Pulse Code Modulation (PCM). Although the default sounds are standard Windows sound-files, local Windows settings might cause these to sound different on different machines. Some users might also have deleted one or more of these sound-files and will therefore be unable to play them. To ensure an identical sound all over, you should import and use your own .wav files encoded in PCM.  |
Add  |
Add sounds to the system. Browse to the sound to upload one or several .wav files.  |
Remove  |
Remove a selected sound from the list of manually added sounds. You cannot remove default sounds.  |
Test  |
Lets you test the sound. In the list, select the sound. The sound is played once.  |
© 2019 Milestone Systems A/S
