Getting started
The XProtect Transact functionality is standard in Management Application. Before using the XProtect Transact features in XProtect Smart Client, you should:
- verify that your base license for XProtect Transact has been activated. In addition, verify that you have a transaction source license for each transaction source that you need to monitor. License information is available under the MIP Plugins node.
If you do not have the sufficient number of transaction source licenses, make sure that you acquire additional licenses before the 30 days grace period expires. - add and configure the sources providing the transaction data, for example the cash registers. For more information, see Add transaction source (wizard).
- (optional) define the transaction events and potentially configure them to trigger rules or alarms. In XProtect Smart Client, the operator can investigate the transaction events.
Even if you have not purchased any XProtect Transact licenses, you can try out XProtect Transact with a trial license. For more information, see XProtect Transact trial license.
See also
Setting up transactions
Setting up events
© 2019 Milestone Systems A/S
