When you configure hardware devices, specify the following properties:
IP Address |
The IP address or host name of the hardware device. |
HTTP Port |
The port to use for HTTP communication with the hardware device. The default is port 80. To use the default port, select Use default HTTP port. |
FTP port |
The port to use for FTP communication with the hardware device. The default port is port 21. To use the default port, select Use default FTP port. |
User name |
Only relevant when you have selected Server requires login. Specify the user name required for using the SMTP server. |
User Name |
The user name for the hardware device's administrator account. Many organizations use the hardware device manufacturer's default user names for their hardware devices. To do so, select "<default>". Do not type a manufacturer's default user name as this can be a source of error. Trust that your system knows the manufacturer's default user name. You can also select other typical user names, such as admin or root, from the list. Type a new user name if you want a user name which is not on the list. |
Password |
Edit the password. Remember to repeat the password to be sure you have specified it correctly. You can only edit this if the selected user is a basic user. |
Hardware type |
Read-only field displaying the type of video device driver used for communication with the hardware device. |
Serial number (MAC address) |
Read-only field displaying the serial number of device. The serial number is usually identical to the 12-character hexadecimal MAC address of the hardware device (example: 0123456789AF). |
License information |
The current license status for the hardware. |
Replace Hardware Device |
Opens a wizard that you can use to replace the selected hardware device with another one if you need to. This can be relevant if you replace a physical camera on your network. The wizard helps you take all relevant issues into account including deciding what to do with recordings from cameras attached to the old hardware device. |
© 2019 Milestone Systems A/S
