Configure hardware devices
Once you have added hardware devices, you can specify/edit device-specific properties including: the IP address, which video channels to use, which COM ports to use for controlling attached PTZ cameras and whether to use Fisheye lens technology.
- Expand Advanced Configuration, expand Hardware Devices, right-click the relevant hardware device, and select Properties.
- Specify Name and video channels, Network, device type and license, PTZ device, and Fisheye lens properties as required.
- Save your configuration changes by clicking Save in the yellow notification bar in the upper-right corner of the Management Application.
© 2019 Milestone Systems A/S
