The following services are all automatically installed on the system server if you run a Typical installation. By default, services run transparently in the background on the system server. If you need to, you can start and stop services separately, see Start and stop services.
Service |
Description |
Milestone Recording Server service |
A vital part of the surveillance system. Video streams are only transferred to your system while the Recording Server service is running. |
Milestone Image Server service |
Provides access to the surveillance system for users who log in with XProtect Smart Client. Note: If the Image Server service is configured in Windows Services to log in with another account than the Local System account, for example as a domain user, installed XProtect Smart Clients on other computers than the surveillance server itself cannot log in to the server using the server's host name. Instead, those users must enter the server's IP address. |
Milestone Image Import service |
Used for fetching pre- and post-alarm images, and storing the fetched images in camera databases. Pre- and post-alarm images is a feature available for selected cameras only that enables sending of images from immediately before and after an event took place from the camera to the surveillance system via e-mail. Pre- and post-alarm images should not be confused with the system's pre- and post-recording feature. |
Milestone Log Check service |
Performs integrity checks on your system's log files. |
Milestone Event Server service |
Manages all alarms and map-related communication. It stores events, image files and map configurations, and makes status information about the surveillance system available. |
Notification server service |
Manages sending email or SMS notifications from the system to users. |
XProtect Mobile service |
Manages the communication between the Recording Server and mobile devices (such as smartphones and tablets) and between the Recording Server and web browsers. |
If you run a Custom installation, you can choose not to install the Event Server. If you do so, the Event Server service is not seen in your Services overview.
© 2019 Milestone Systems A/S
