Start and stop services
On a system server, several services by default run in the background. If you need to, you can start and stop each service separately:
- Expand Advanced Configuration and select Services. This displays the status of each service.
- You can now stop each service by clicking the Stop button. When a service is stopped, the button changes to Start, allowing you to start the service again when required.
© 2019 Milestone Systems A/S
