Available functionality depends on the system you are using. See the Product comparison chart for more information.
When you configure scheduling for PTZ (pan-tilt-zoom) cameras capable of patrolling, you can specify which patrolling profiles to use at specific times. Before you can define this type of schedule, you must configure patrolling for the relevant cameras.
| PTZ Patrolling | Only available for PTZ cameras that have PTZ patrolling capabilities. Select the required profile for the PTZ patrolling schedule for the camera(s) in question. Specify a camera's patrolling schedule based on patrolling profiles within particular periods of time (example: Mondays from 08.30 until 17.45), shown in red:  |
Use of one patrolling profile may be followed immediately by use of another. Example: use the Daytime patrolling profile Mondays from 08.30 until 17.45, then the Evening patrolling profile Mondays from 17.45 until 23.00. Use of two patrolling profiles cannot overlap.
Unlike other types of scheduling, there are no ready-made Always on and Always off schedule profiles for PTZ patrolling. You can create any number of customized schedule profiles for each camera. When you create a customized schedule profile for one camera, you can reuse it with other cameras if required.
© 2019 Milestone Systems A/S
