Configure Matrix
Available functionality depends on the system you are using. See the Product comparison chart for more information.
  1. Expand Advanced Configuration, right-click Matrix and select Properties.
  2. Enable the use of Matrix by selecting the Enable Matrix check box.
  3. Specify required properties, or, for automatically triggered video sharing, select Matrix Event Control and configure Matrix Event Control properties. When ready, click OK.
  4. Save your configuration changes by clicking Save in the yellow notification bar in the upper-right corner of the Management Application.
© 2019 Milestone Systems A/S
