Available functionality depends on the system you are using. See the Product comparison chart for more information.
Use the Matrix Recipients tab to enable Matrix functionality and to define which computers to display Matrix-triggered live video. A computer on which Matrix-triggered video can be displayed is known as a Matrix-recipient. Being able to view Matrix-triggered video requires that you have installed XProtect Smart Client on the user's computer.
Enable Matrix |
Select the check box to enable Matrix functionality. |
[List of Defined Matrix recipients] |
Lists any already defined Matrix recipients, that is, computers on which Matrix-triggered video can be displayed. To change the properties of an already defined Matrix recipient, select the required Matrix recipient, make the changes in the fields below the list, then click the Update button. To remove a Matrix recipient from the list, select the unwanted Matrix recipient, then click the Delete button. |
Name |
Name of the Matrix-recipient. Use this when you add a new Matrix-recipient or edit the properties of an existing one. The name appears in various day-to-day usage situations. Milestone recommends that you use a name for this that is descriptive and easy to remember. Names must be unique, and must not contain any of these special characters: < > & ' " \ / : * ? | [ ] |
Address |
IP address of the Matrix recipient, used when adding a new Matrix recipient or editing the properties of an existing one. |
Port |
Specify the port number to be use when sending commands to the Matrix recipient. Use when you add a new Matrix recipient or edit the properties of an existing one. The Matrix recipient listens for commands on this port. By default, the system uses port 12345. You can change the port if you need to. |
Password |
Specify the password to be use when the system communicates with the Matrix recipient. Use this when you add a new Matrix recipient or edit the properties of an existing one. |
Matrix-recipient is an XProtect Smart Client |
Select if the relevant Matrix-recipient is XProtect Smart Client. If you use XProtect Smart Client, distribution of Matrix-triggered live video takes place slightly differently. |
Clear |
Removes any content in the Name, Address, and Password fields. |
Update |
Updates the properties of the selected Matrix recipient with the changes made during editing. Available only if you have edited the properties of an existing Matrix recipient. |
Add |
Adds the new Matrix-recipient to the list. Available only if you have added properties of a new Matrix-recipient in the Name, Address, Port, Password, and possibly XProtect Smart Client fields. |
© 2019 Milestone Systems A/S
