Delete/disable hardware devices
Important: If you delete a hardware device, you not only delete all cameras, speakers and microphones attached to the hardware device. You also delete any recordings from cameras on the hardware device.
- Expand Advanced Configuration, expand Hardware Devices, right-click the hardware device you want to delete, and select Delete Hardware device.
- Confirm that you want to delete the hardware device and all its recordings.
- Save your configuration changes by clicking Save in the yellow notification bar in the upper-right corner of the Management Application.
- Restart the Recording Server service.
Alternately, you can also consider disabling the individual cameras, speakers or microphones connected to the hardware device:
- Expand Advanced Configuration, expand Hardware Devices, and expand the relevant hardware device.
- Right-click the camera, microphone or speaker that you want to disable, and select Disable.
© 2019 Milestone Systems A/S
