The Adjust Motion Detection wizard helps you quickly configure your cameras' motion detection properties.
Cameras that do not support multiple simultaneous video streams cannot connect to the surveillance server and the Management Application at the same time. Milestone recommends that you stop the Recording Server service when you configure such devices for motion detection and PTZ.
See also View video from cameras in the Management Application.
In this section |
© 2019 Milestone Systems A/S
