All cameras are enabled by default. This means that video from the cameras can be transferred to your system if the cameras are scheduled to be online.
To disable a camera:
To delete a camera, you have to delete the hardware device. If you delete the hardware device, you also delete any attached microphones or speakers. If you do not want this, consider disabling the camera instead.
© 2019 Milestone Systems A/S
