About database resizing
In case recordings for a camera get bigger than expected, or the available drive space is suddenly reduced in another way, an advanced database resizing procedure automatically takes place:
- If archives are present on the same drive as the camera's database, the oldest archive for all cameras archived on that drive is moved to another drive (moving archives is only possible if you use dynamic archiving, with which you can archive to several different drives) or—if moving is not possible—deleted.
- If no archives are present on the drive containing the camera's database, the size of all camera databases on the drive is reduced by deleting a percentage of their oldest recordings, temporarily limiting the size of all databases.
When the Recording Server service is restarted upon such database resizing, the original database sizes are used. Therefore, you should make sure to solve the drive size problem. Should the database resizing procedure take place, you are informed on-screen in XProtect Smart Client, in log files, and, if set up, through notifications.
© 2019 Milestone Systems A/S
