When you configure Time profiles, specify the following:
Name |
Type a name for the time profile. |
Description |
Enter a description (optional). |
Add Single Time |
Right-click the calendar and select Add Single Time. Specify Start time and End time. If the time covers whole days, select All-day event. |
Add Recurring Time |
Right-click the calendar and select Add Recurring Time. Specify the time range, recurrence pattern, and range of recurrence. |
Edit Time |
Right-click the calendar and select Edit Time. Specify Start time and End time. If the time covers whole days, select All-day event. When you edit an existing time profile, remember that a time profile may contain more than one time period, and that time periods may be recurring. If you want your time profile to contain additional periods of time, add more single times or recurring times. |
© 2019 Milestone Systems A/S
