Add a time profile (for alarms)
Time profiles are periods of time used for the Alarms feature only.
To add a time profile for an alarm, do the following:
- Expand Alarms, right-click Time Profiles, and select Create New. The small month overview in the top right corner of the Time Profile Properties window can help you get a quick overview of the time periods covered by the time profile, as dates containing specified times are highlighted in bold.
 - In the calendar, select the Day View, Week View, or Month View tab, then right-click inside the calendar and select either Add Single Time... or Add Recurring Time....
 - If you select Add Single Time..., specify Start time and End time. If the time is to cover whole days, select the All-day event box.
—or—
If you select Add Recurring Time..., specify time range, recurrence pattern, and range of recurrence. Click OK. - Save your configuration changes by clicking Save in the yellow notification bar in the upper-right corner of the Management Application.
When you edit an existing time profile, remember that a time profile may contain more than one time period, and that time periods may be recurring.
    © 2019 Milestone Systems A/S
