After you create an analytics event, you can test the requirements, for example that the analytics events feature has been enabled in Management Application.
As an additional test, in XProtect Smart Client you can verify that the analytics event was sent to the event server. To do this, open XProtect Smart Client and view the event in the Alarm Manager tab.
See also
Analytics events (explained)
© 2019 Milestone Systems A/S
