The use of XProtect Access requires that you have purchased a base license that allows you to access this feature within your XProtect system. You also need an access control door license for each door you want to control.
Name |
Description |
Show development property panel |
If selected, developer information is shown under Access Control properties. This setting is only meant to be used by developers of access control system integrations. |
© 2019 Milestone Systems A/S
